It is currently Sat Sep 13, 2025 11:38 am
PostPosted: Tue Oct 18, 2016 12:37 pm
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
In the midst of building my second soprano uke. Hand bent the sides continuous out of a beautiful piece of curly maple with the joint at he neck. Other than a thickener for the possible inclusion of a strap button, do I really need a tail-block? I may be naive but I really can't come up with a logical argument that says I absolutely need to have one. The soprano body is so small that leaving out the tail block would just make it that much lighter. I don't plan on installing a tail wedge because there is no tail joint. Feedback appreciated...
Peter
PostPosted: Tue Oct 18, 2016 1:20 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
If there is a reason to include one, I can't think of it. You mention the only reason I could come up with, strap button, but I wouldn't think anyone would put one on a soprano. Who knows though maybe they would.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: Peter J (Tue Oct 18, 2016 4:09 pm)
PostPosted: Tue Oct 18, 2016 6:03 pm
First name: Kevin
Last Name: Mason
City: Wheeling
State: IL
Zip/Postal Code: 60090
I find that, the smaller the instrument, the harder it is to hold. If you don't put an end strap button now, you might want to later, and for that you need an end block. Mine are only 1.5-1.75 inches wide and .5 inches deep. The weight is insignificant.
Kevin Mason
Mason Guitars and Ukuleles on Facebook
http://masonguitars.net
These users thanked the author Kevin Mason for the post: Peter J (Wed Oct 19, 2016 10:28 am)
PostPosted: Wed Oct 19, 2016 11:33 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
There's no NEED to have one if you don't have a joint there. Especially in a soparano size. (For a guitar I'd recommend some reinforcement at the butt because that's where it gets bumped when you set it down.) I don't see many soprano players use a strap, but just cradle it while playing
These users thanked the author Quine for the post: Peter J (Wed Oct 19, 2016 1:42 pm)
PostPosted: Wed Oct 19, 2016 5:47 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
I've built a couple of sopranos with a one piece side and didn't use a tail block. They're holding together fine.
However, I did double the lining where the top joins the tail for about two inches (I use 1.5 mm solid linings). My reasoning was that this is the point where the strings' efforts to peel up the top are strongest. Probably not necessary, especially if you use wider linings, but it gave me some comfort.
These users thanked the author profchris for the post: Peter J (Thu Oct 20, 2016 8:12 am)
PostPosted: Wed Nov 09, 2016 12:50 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I use a small piece of baltic birch plywood as mentioned in the gore/gilet book. I also like to make a lot of different styles of butt end graft shapes. So no tail block would not work for me. I see nothing wrong with making a 1piece or laminate sides minus the rear block. or as others mentioned some lining
These users thanked the author ernie for the post: Peter J (Sat Nov 12, 2016 9:28 am)
